LucaBilla
Nov 17, 2021Star
R9000 - WAN VLAN Setting
Hello Community! I posted this problem days ago in the Italian Community but no "reasonable" answer received. So I'm trying here :) In Italy if you need to use your Router with Fastweb (Italian IS...
LucaBilla
Nov 18, 2021Star
I tried DD-WRT but the configuration is quite "complicated".
You should have BIG competences in Linux / Networking domain, not exactly the use case an "home" router is pointing to.
I didn't succeeded in configure it, and I have "some" competences in it.
We do "simply" need a checkbox in the "internet wan" configuration tab where to indicate the VLAN id for the WAN, nothing complicated.
(All the other routers, also the cheapest ones, have it).
Nov 18, 2021Guru - Experienced User
I'd post about that over in the DD-WRT forums. Someone there may have more help and information regarding this and DD-WRT.
