duckpuckstick
Apr 15, 2022Aspirant
R9000 + CM600 | Plex Server Not Available Outside of Network
Cannot for the life of me get Remote Access to work without relay. I am running Plex off my Nighthawk X10 R9000. It’s connected to a Netgear CM600 so Double NAT is not my problem. The Private IP ...
- Oct 05, 2022
Changing my port number from 32400 to 32401 in Remote Access resolved my issue.
michaelkenward
Apr 16, 2022Guru - Experienced User
What does "relay" have to do with it?
I ask because Remote Access can mean various things and "relay" is new one to me.
Netgear has been playing around with "remote" features.
Remote Management is now Anywhere Access in the Nighthawk and Orbi apps | Answer | NETGEAR Support
- duckpuckstickApr 16, 2022Aspirant
Relay relays the server through Plex and limits the bandwidth to 2mbps for PLex Pass users. The quality is unbearable.
