duckpuckstick
Apr 15, 2022Aspirant
R9000 + CM600 | Plex Server Not Available Outside of Network
Cannot for the life of me get Remote Access to work without relay. I am running Plex off my Nighthawk X10 R9000. It’s connected to a Netgear CM600 so Double NAT is not my problem. The Private IP ...
- Oct 05, 2022
Changing my port number from 32400 to 32401 in Remote Access resolved my issue.
duckpuckstick
Apr 16, 2022Aspirant
I do not want to use relay whatsoever. Unchecking that doesnt do anything. Resetting the router doesnt do anything. Restarting plex doedsnt do anything. Disabling and reenablling remote access doesnt solve anything.
Apr 16, 2022Guru - Experienced User
So from reading about relay, you still have to have you plex server online to use it.
So your server is online and working, but for some reason its forcing it to go through relay.
You'll need to follow plex's faq on remote access to get it working
- plemansApr 16, 2022Guru - Experienced Useryou said you've factory reset the system?
- duckpuckstickApr 17, 2022Aspirant
Yes I have reset it and the FAQ doesnt solve my problem. Ive went through everything. I just gave up and put it back on my PC.
- duckpuckstickOct 05, 2022Aspirant
- FURRYe38Oct 06, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
