duckpuckstick
Apr 15, 2022Aspirant
R9000 + CM600 | Plex Server Not Available Outside of Network
Cannot for the life of me get Remote Access to work without relay. I am running Plex off my Nighthawk X10 R9000. It’s connected to a Netgear CM600 so Double NAT is not my problem. The Private IP ...
- Oct 05, 2022
Changing my port number from 32400 to 32401 in Remote Access resolved my issue.
Apr 16, 2022Guru - Experienced User
you said you've factory reset the system?
duckpuckstick
Apr 17, 2022Aspirant
Yes I have reset it and the FAQ doesnt solve my problem. Ive went through everything. I just gave up and put it back on my PC.
- duckpuckstickOct 05, 2022Aspirant
- FURRYe38Oct 06, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
