dustinf2005's avatar
dustinf2005
r9000 100mbps Limit
Hi,   I have a r9000 Netgear Nighthawk X10 AD7200 that is a little over 2 years old. It has been factory reset to the default settings, and is running the latest firmware (1.0.5.18). This router is...
  • plemans's avatar
    Aug 11, 2020
    maybe the port went bad.
    If you go to the ip address/debug.htm  (so: usually 192.168.1.1/debug.htm)  or whatever you use for your ip address, most routers have a wan port mirror to port 1. Not 100% on the R9000 as I don't have one but all my other routers have some form of it. try checking that, reboot the router using port 1 of the lan ports as a wan port.
