Mtnman1
Feb 19, 2023Aspirant
R9000-100NAS
I cant open the VPN license key after setting up the files on my PC. windows 10 how can I get that so I can enter it in the windows VPN set up.
Mtnman1
Feb 20, 2023Aspirant
Ok ya I did all that, but it says there's a network cable unplugged? lol
Kitsap
Feb 20, 2023Master
Mtnman1 wrote:Ok ya I did all that, but it says there's a network cable unplugged? lol
You cannot test your Open VPN setup with a device that is connected to the same network where the Open VPN server is running.
If you have a mobile device, you can shut off the Wi-Fi and test through your cell connection. If you have a laptop and a mobile device, activate the hotspot on your mobile device and connect your laptop through the hotspot.
On either a mobile device or computer, you have to start the Open VPN application and connect back to the Open VPN server before use.
