Retired_Member
Jul 21, 2019R9000 160MHz can not enable
I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed. I live in Europe, so have european wifi region set,...
- Jul 22, 2019
Retired_Member wrote:I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed.
People usually don't post successful config updates, this might affect the number of related posts.
Had enabled it before, it's working as of 1.0.4.28, and currently on a early access version (for some other bugfixes) - also on Europe regulatory settings Possible dependency might be on the channel setting - not sure if the second one does show up without the secondary VT80 enabled however:
schumaku
Jul 22, 2019Guru - Experienced User
