Retired_Member
Jul 21, 2019R9000 160MHz can not enable
I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed. I live in Europe, so have european wifi region set,...
- Jul 22, 2019
Retired_Member wrote:I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed.
People usually don't post successful config updates, this might affect the number of related posts.
Had enabled it before, it's working as of 1.0.4.28, and currently on a early access version (for some other bugfixes) - also on Europe regulatory settings Possible dependency might be on the channel setting - not sure if the second one does show up without the secondary VT80 enabled however:
schumaku
Jul 22, 2019Guru - Experienced User
Retired_Member
Jul 22, 2019Thanks for taking an interest in my problem I appreciate it! :smileyhappy:
Good to know that its not apparently a FW issue.
In other posts I have noticed that it may be a channel selection issue that prevents me from enabling it, but unlike you, I'm for some reason unable to select 2 DFS channels - If I select a non-DFS channnel as the primary, the dropdown menu for the secondary VHT80 channel only shows DFS channels, and vice versa - if a DFS is selected as a primary channel, only non-DFS channels can be selected for the secondary.
I have however not tried with those 2 specific channels, so I'll give that a go this evening - and report back! (But i suspect the same issue will occur, that I'm not able to select 2 DFS channels)
cheers
Mark
