Retired_Member
Jul 21, 2019R9000 160MHz can not enable
I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed. I live in Europe, so have european wifi region set,...
- Jul 22, 2019
Retired_Member wrote:I'm trying to enable 160MHz bandwidth channels on my R9000 without success. I have read quite a few forum threads, but all attempts have failed.
People usually don't post successful config updates, this might affect the number of related posts.
Had enabled it before, it's working as of 1.0.4.28, and currently on a early access version (for some other bugfixes) - also on Europe regulatory settings Possible dependency might be on the channel setting - not sure if the second one does show up without the secondary VT80 enabled however:
schumaku
Jul 22, 2019Guru - Experienced User
Retired_Member
Jul 29, 2019So I finally got around to mucking about with this again, and indeed it worked like a charm - thank you very much for your help!
To others having the same issues I learned the following from Schumaku's post.
- I had to select 2 DFS channels as the primary and secondary channels.
- You need to select channels that are at least 16 numbers, or 4 channels apart to enable 160MHz bandwidth.
- You CAN select, like I tried at first, select channel 112 and 116 as primary and secondary, thinking this would support both 160MHz contiguous and 80+80, but THIS WILL NOT ENABLE YOU TO SELECT 160MHz bandwidth.
- Therefore selecting channel 100 as primary, means channels 100, 104, 108, 112 are used for quad streams(see under advanced tab, Advanced Home). And select channel 116 as secondary, means this uses channels 116, 120, 124, 128 (again, see this under Advanced Home). THIS ENABLES 160MHz BANDWIDTH CHANNEL SELECTION.
I hope this will help others having similar trouble.
Once again thanks to Schumaku!
