Carterblumeyer
Sep 28, 2024Aspirant
R9000 2.4 & 5Ghz radio not on but 60Ghz is
I am trying to figure out why the 2.4 & 5Ghz radio stop working. No lights on them but 60Ghz is on. I have done a factory reset, downgraded and upgraded firmware versions. The web interface show they ...
Oct 06, 2024Guru - Experienced User
You two can take a look at this link and see if it could help. I had a XR700 that was in a similar condition that radios failed to work and nothing would get it working right until I followed this process. Got the radios working right on my XR700 which is based off the R9000 BTW:
https://forum.netduma.com/topic/51612-new-xr700-beta-firmware-33363/?do=findComment&comment=381931
If you need more information or help, I'd head over to SMB forums and make contact with Kamoj user there.
If this doesn't get the radios working, then I would presume the radios may have just gone bad and either router needs to be replaced or disable ALL radios on the router and connect up some upgraded WiFi AP systems since the R9000 is EoL.
Good Luck.
