GTiVR6r's avatar
GTiVR6r
R9000 2.4GHz band too wide
I purchased the Netgear Nighthawk R9000 router to replace my older R7000 and began to hard wire certain devices in my house. (TVs, PS4, Office computers...) I have noticed on the new R9000 router th...
  • TheEther's avatar
    TheEther
    Dec 10, 2017
    In your last reply, you meant to say Mbps, not MHz.
    Anyway, it may seem like the R9000 is slower, but that's not really the case.
    The maximum 2.4 GHz speeds supported by the R9000 (800 Mbps) and R7000 (600 Mbps) use non-standard modulation, 256-QAM. You would need a device that supports 256-QAM. Well, there really isn't any computer or smartphone that supports it. The fastest, standard speeds are really 600 Mbps and 450 Mbps, respectively.
    But these are speeds using 40 MHz channels. With 20 MHz channels, these speeds drop to 289 Mbps and 217 Mbps, respectively.
    But there is a second requirement to hit those respective speeds. The R9000 requires a device to support 4 streams.  The R7000 requires 3 streams. High-end laptops, like Macbook Pros and premium PC laptops, support 3 streams. All smartphones use either 1 or 2 streams. There are only a handful of Wi-Fi adapters that support 4 streams and, AFAIK, they all require a PCI-E slot in a desktop computer. Unless you have one of these rare adapters, your devices are going to use between 1 and 3 streams. The R9000 can obviously handle devices with fewer than 4 streams; it will basically perform that same as the R7000. Yes, that means that the R9000's 4th stream isn't really going to do you much good.
    I think you will do well to return the R9000 and hardwire as much as possible. Ethernet is more reliable, has lower latency and is, for the moment, faster than Wi-Fi.
