SRC54
Sep 01, 2023Tutor
R9000 5 yo router isn't seen my Mac Mini M2 in 5G unless I slow down speed from 1700 to 800
I thought I had a bad Mac at first as it just wouldn't find my 5G network so was stuck on 2.4G. Then I noticed it could see my neighbors 5G. I tried everything; changing channels, renaming the netw...
- Sep 01, 2023
If your not really using the higher speeds or have lots of devices using it, i'd keep what you have configured so the mini will work. At some point the 9000 will need to be retired and find you something that has 6E or even WiFi 7.
Sep 01, 2023Guru - Experienced User
If all other devices are working with 160Mhz enabled and this one is not, would point to something this one device is not working right or is not supporting of.
You could try installing some 3rd party FW on the router to see if the may help or not:
https://www.snbforums.com/forums/netgear-ac-wireless-wi-fi-5.53/
Give Voxel's a try. You can revert back to stock at any time.
Kitsap
Sep 01, 2023Master
Trying to find a configuration to reliably transmit/receive 5G Wi-Fi over a 160 MHz wide channel can be elusive. Much depends on how crowded your radio frequency environment is and your access to DFS channels.
For some background reading, check out chapter 14 of the Duckware document here:
https://www.duckware.com/tech/wifi-in-the-us.html
- KitsapSep 01, 2023Master
If you upgrade stock or change to Voxel firmware, be sure to use the same Wi-Fi names (SSIDs) and passwords. Your various Wi-Fi connected devices should transition without issue.
- SRC54Sep 01, 2023Tutor
Thanks, I am reading the site; fear a lot of it is Greek to me. But I will keep reading.
