Twwphd
Oct 30, 2017Aspirant
R9000 5GHz visible but cannot connect. 2.6 band is fine
Had XBox S and new Samsung UHD 65 connected via 5GHz and had worked fine until a month ago. My Samsung Note5 gets an "authentication error" and fails to connect as well. The R9000 has the latest ...
- Nov 06, 2017
Try to factory reset the router and see if that will help.
Resetting will wipe out all the settings of the router, so you will need reconfigure it after.
You may want to use backup and restore feature for easy reconfiguration.
