user12a
Oct 10, 2020Star
R9000 AD7200 x10 Firmware Ver 1.0.5.24 kills WiFi
It seems frustrating upgrading firmware on the Netgear x10 R9000 . I recently upgraded to current version 1.0.5.24 and all the Wifi (2.4, 5, 60) cannot be enabled, all come in off state after power on...
- Apr 15, 2021
Did you erase the nvram using the following commands via serial connection?
nvram erase
go
user12a
Oct 12, 2020Star
I used the Kong build R9000-factory-to-ddwrt.img dated 3-18-2019.
Found at:
ftp://gakinaction.ddns.net/Kong%20PTB/3-23-2019/K4-AC-ALPINE/
Then you can upgrade to any bin in the dd-wrt repository.
To go back to factory, I was unable to get the R9000 in TFTP mode.
However it is easy to just flash it back within dd-wrt with ddwrt-netgear-R9000.bin 2/21/17
found in MyOpenForum.com, which brings back to Netgear ver 1.0.1.35
dd-wrt bin fixes the R9000 WiFi but my experience with dd-wrt builds is that the USB file share is extremely slow.
Still have not heard back from anyone with Netgear to help.
user12a
Oct 12, 2020Star
It is MyOpenRouter, not MyOpenForum.com
