user12a
Oct 10, 2020Star
R9000 AD7200 x10 Firmware Ver 1.0.5.24 kills WiFi
It seems frustrating upgrading firmware on the Netgear x10 R9000 . I recently upgraded to current version 1.0.5.24 and all the Wifi (2.4, 5, 60) cannot be enabled, all come in off state after power on...
- Apr 16, 2021
Did you erase the nvram using the following commands via serial connection?
nvram erase
go
NighthawkTech
Apr 21, 2021Aspirant
I tried the commands on my R9000. Wifi still dead. Is Kamoj add-on mandatory for this procedure?
user12a
Apr 22, 2021Star
Resetting nvram has nothing to do with loading any add-on.
You need to verify if you indeed have a hardware issue.
My router wifi worked with the dd-wrt FW but not with NG's after firmware upgrade. You may want to try dd-wrt or openwrt FW to verifiy your hardware first. They use different nvram structure.
Good luck.
