Ra-Dzik's avatar
Ra-Dzik
Apprentice
Sep 03, 2018
R9000 an AC wireless speed
Hello,   how much Mb/s do you achive by AC wireless connection on R9000?   I'm only reaching max 35 Mb/s (120/10 Mb/s from my ISP) on two different laptops in few locations in my home when I ...
  • Ra-Dzik's avatar
    Ra-Dzik
    Sep 09, 2018
    I FOUND SOLUTION (OR RATHER HINT) FOR WIFI PERFORMANCE PROBLEM!!!
    Normally I had max 30Mb/s download. I made backup for router settings on local computer. After that I made factory reset defaults. After router reboot I loaded backup from file. And now I have 99,9% nominal speed from my ISP!
    And let someone say that Netgear router R900 is a premium/polished product! Unfortunately not. I decided to resign from R9000 and now I complain this router in shop I started procedure to return R9000 to shop and I want to give my money back! It's a waste of time and nerves
