Lextacy03
Feb 11, 2021Initiate
R9000 and Mesh Wifi 6 system
Hello Community, I have the Nighthawk R9000 Router and recieved the Nighthawk Mesh 6 system as a gift. Is it possible to connect the mesh system to the r9000 to create a system that covers more...
Feb 12, 2021Guru - Experienced User
The r9000 isn't a mesh router. So it won't fully integrate with your mesh system.
Not saying you can't use it. how you could set it up?
modem----->r9000------>mesh system in ap (access point) mode.
set the r9000 with its own ssid seperate from the mesh system so it doesn't mess up the smart roaming of the mesh system.
Then you could use the r9000 as a backup or even to offload some devices off the mesh.
