rusman
May 28, 2017Tutor
R9000 block ssl-vpn connection ( port 443)
Hi All, i have issue with connecting to SSL VPN on port 443, i have R9000 router, i use firmware v1.0.1.36 When i tryed to connect to my work with Cisco Anyconnect that use port 443 i get denied....
- Jun 02, 2017
Hi All,
Just to Update,
Reload the router and SSL VPN worked correctly.
May be was some issue with MTU like TheEther say...
Will continues to monitor if it will happen again will update.
Thanks for you all for trying to help.
Ruslan.
rusman
May 29, 2017Tutor
Hi,
thanks for reply.
ISP Modem is D-link ( bridge mode)
no Port Fowrading rules exist on the router.
R9000 don't have any option to disable protetion.
i think the algorith that R9000 use to recognize DDOS is incorrect.
Ruslan.
rusman
May 29, 2017Tutor
we can see on the packet capture that was take from the router,
R9000 Reset the connection after get response from remote peer 84.XXX.XXX.XXX
Source 31.XX.XXX.XXX
i think if i will restart the router everything wil work correctly...but i don't belive is such solutions.:)
few weeks ago everything worked correctly.
If need more info update me.
Thanks.
Ruslan.
- TheEtherMay 29, 2017Guru
Oh boy, the Wireshark trace is a tale of dueling TCP RST exchanges.
You can see in frame 264 that the remote peer has replied with the wrong ACK number (2010615401) in response to the local host's TCP SYN request in frame 263. Wireshark flags this as ACKed unseen segment. The local host immediately sends a TCP RST (Reset) to tear down the connection in frame 265.
The remote peer retransmits frame 264 again as frame 327 in spite of the TCP RST in frame 265. It's almost as if the remote peer didn't receive the RST. The local host sends another RST in frame 330. The remote peer does this two more times in frame 470 and 1015. Each time the local host sends a RST in 471 and 1016.
Frame 940 is where we see a RST out of the blue from the remote peer. This RST doesn't seem to match up with any of the other frames. Frame 940 is probably what Netgear is flagging as a RST Scan.
Based on the above, it seems to me that the remote peer at 84.xxx.xxx.xxx is not behaving properly, although I guess we can't rule out the possibility that the router is totally mangling the traffic. It would be interesting to see simultaneous Wireshark captures from both sides of the router (i.e. WAN and LAN). This would provide insight into what the router is doing to the traffic pre- and post-NAT.
- rusmanMay 29, 2017Tutor
Hi The Ether,
thanks for answer,
of course i can provide LAN and WAN capture on the router,
please see picture below:
WAN:
My Home IP:31.XXX.XXX.XXX
Remote Peer: 84.XX.XXX.XXX
LAN:
PC:192.168.9.248
Remote Peer: 84.XXX.XXX.XXX
Of couse i have acces to remote peer it's Cisco ASA Firewall,
same pc 4G or modem directly connected i can succesfully conect to vpn.
i also added some files from R9000 ( basic_debug_log,console.log)
May be it will help.
Thanks for help,
Ruslan.
Basic_debug_log:
ath0 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:23
inet6 addr: fe80::9e3d:cfff:fee2:b123/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:12678460 errors:0 dropped:0 overruns:0 frame:0
TX packets:28120983 errors:46868 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2126025531 (1.9 GiB) TX bytes:273754668 (261.0 MiB)ath1 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:21
inet6 addr: fe80::9e3d:cfff:fee2:b121/64 Scope:Link
RX packets:42582219 errors:1 dropped:1 overruns:0 frame:0
TX packets:67680490 errors:74509 dropped:0 overruns:0 carrier:0
RX bytes:3272440133 (3.0 GiB) TX bytes:1880228954 (1.7 GiB)br0 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:21
inet addr:192.168.9.254 Bcast:192.168.9.255 Mask:255.255.255.0
RX packets:107647059 errors:0 dropped:652 overruns:0 frame:0
TX packets:166335214 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:30349962889 (28.2 GiB) TX bytes:189145974449 (176.1 GiB)brwan Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:22
inet6 addr: fe80::9e3d:cfff:fee2:b122/64 Scope:Link
RX packets:160004128 errors:0 dropped:0 overruns:0 frame:0
TX packets:99264210 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:187053650462 (174.2 GiB) TX bytes:30812712705 (28.6 GiB)eth0 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:25
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)eth1 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:21
RX packets:58972233 errors:0 dropped:0 overruns:0 frame:0
TX packets:80139346 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1367066474 (1.2 GiB) TX bytes:2512704123 (2.3 GiB)eth2 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:22
TX packets:99264219 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2370056734 (2.2 GiB) TX bytes:3667115706 (3.4 GiB)ethlan Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:21
RX packets:58972233 errors:0 dropped:13785 overruns:0 frame:0
TX packets:80139340 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:18546935658 (17.2 GiB) TX bytes:80924567912 (75.3 GiB)ethwan Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:22
TX packets:99264213 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:187053650462 (174.2 GiB) TX bytes:30812712935 (28.6 GiB)lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:34721163 errors:0 dropped:0 overruns:0 frame:0
TX packets:34721163 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1391686211 (1.2 GiB) TX bytes:1391686211 (1.2 GiB)ppp0 Link encap:Point-to-Point Protocol
inet addr:XX.XXX.XX.XX P-t-P:212.179.37.1 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:14162226 errors:0 dropped:0 overruns:0 frame:0
TX packets:10244988 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:15916442983 (14.8 GiB) TX bytes:1913778140 (1.7 GiB)tap0 Link encap:Ethernet HWaddr 22:93:B8:B4:F9:07
inet6 addr: fe80::2093:b8ff:feb4:f907/64 Scope:Link
UP BROADCAST RUNNING PROMISC MULTICAST MTU:1500 Metric:1
RX packets:946202 errors:0 dropped:285 overruns:0 frame:0
TX packets:2155258 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:616788875 (588.2 MiB) TX bytes:480648553 (458.3 MiB)tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:192.168.10.1 P-t-P:192.168.10.1 Mask:255.255.255.0
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
TX packets:82 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:6920 (6.7 KiB)wifi0 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:23
collisions:0 txqueuelen:539
Interrupt:166 Memory:f1c00000-f1e00000wifi1 Link encap:Ethernet HWaddr 9C:3D:CF:E2:B1:21
Interrupt:167 Memory:f2000000-f2200000MemTotal: 1030732 kB
MemFree: 815012 kB
Buffers: 10416 kB
Cached: 28372 kB
SwapCached: 0 kB
Active: 20796 kB
Inactive: 26404 kB
Active(anon): 8772 kB
Inactive(anon): 3996 kB
Active(file): 12024 kB
Inactive(file): 22408 kB
Unevictable: 0 kB
Mlocked: 0 kB
HighTotal: 270336 kB
HighFree: 229356 kB
LowTotal: 760396 kB
LowFree: 585656 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 8620 kB
Mapped: 4008 kB
Shmem: 4356 kB
Slab: 54340 kB
SReclaimable: 2984 kB
SUnreclaim: 51356 kB
KernelStack: 1560 kB
PageTables: 1224 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 515364 kB
Committed_AS: 287520 kB
VmallocTotal: 245760 kB
VmallocUsed: 22244 kB
VmallocChunk: 171148 kB
AnonHugePages: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
PID Uid VmSize Stat Command
1 root 356 S init
2 root SW [kthreadd]
3 root SW [ksoftirqd/0]
5 root SW< [kworker/0:0H]
6 root SW [kworker/u8:0]
7 root SW [migration/0]
8 root SW [rcu_bh]
9 root SW [rcu_sched]
10 root SW [migration/1]
11 root SW [ksoftirqd/1]
13 root SW< [kworker/1:0H]
14 root SW [migration/2]
15 root SW [ksoftirqd/2]
17 root SW< [kworker/2:0H]
18 root SW [migration/3]
19 root SW [ksoftirqd/3]
21 root SW< [kworker/3:0H]
22 root SW< [khelper]
23 root SW [kdevtmpfs]
24 root SW< [writeback]
25 root SW< [bioset]
26 root SW< [kblockd]
27 root SW [kworker/3:1]
28 root SW< [ata_sff]
29 root SW [khubd]
30 root SW [kworker/u8:1]
37 root SW< [md]
38 root SW< [edac-poller]
39 root SW [kworker/2:1]
40 root SW< [rpciod]
41 root SW< [kvm_arch_timer]
43 root SW [kswapd0]
44 root SWN [khugepaged]
45 root SW [fsnotify_mark]
46 root SW [ecryptfs-kthrea]
47 root SW< [nfsiod]
48 root SW< [cifsiod]
49 root SW< [xfsalloc]
50 root SW< [xfs_mru_cache]
51 root SW< [xfslogd]
52 root SW< [crypto]
70 root SW [kworker/1:1]
71 root SW [nvme]
72 root SW< [fd882000.spi]
73 root SW< [kpsmoused]
110 root SW< [deferwq]
111 root SW [ubi_bgt0d]
112 root SW< [kworker/0:1H]
116 root SW< [kworker/1:1H]
124 root SW< [kworker/2:1H]
181 root SW [ubifs_bgt0_5]
191 root SW [ubi_bgt1d]
208 root SW [ubifs_bgt1_0]
240 root 132 S /bin/sh /etc/init.d/rcS S boot
242 root 356 S logger -s -p 6 -t sysinit
248 root 88 S init
264 root 416 S /bin/sh /sbin/cpu_temperature
561 root 268 S klogd
565 root SW< [kworker/3:1H]
566 root 560 S /bin/datalib
606 root 276 S /sbin/watchdog -t 5 /dev/watchdog
612 root SW< [cfg80211]
629 root SW< [wil6210_wmi]
630 root SW< [wil6210_service]
631 root SW [irq/147-wil6210]
636 root SW< [bond0]
740 root 528 S /sbin/hotplug2 --override --persistent --set-rules-fi
894 root 76 S /sbin/ubusd
1108 root 244 S /usr/bin/detcable 2
2132 root 352 S udhcpd /tmp/udhcpd.conf
3500 root 268 S /usr/sbin/miniupnpd
3768 root 304 S /usr/sbin/ntpclient
3808 root 376 S crond -c /tmp/etc/crontabs -T GMT+8
4375 root SW< [alloc_task_wque]
4580 root 1724 S /usr/sbin/openvpn /tmp/openvpn/server_tap.conf
4583 root 576 S /usr/sbin/openvpn /tmp/openvpn/server_tun.conf
4958 root 316 S /usr/sbin/net-scan
4962 root 272 S lld2d br0
5143 root SW< [alloc_task_wque]
6265 root 856 S hostapd -P /var/run/wifi-ath1.pid -B /var/run/hostapd
6267 root 296 S hostapd_cli -i ath1 -P /var/run/hostapd_cli-ath1.pid
6740 root 856 S hostapd -P /var/run/wifi-ath0.pid -B /var/run/hostapd
6742 root 296 S hostapd_cli -i ath0 -P /var/run/hostapd_cli-ath0.pid
8060 root 356 S /usr/sbin/uhttpd -h /www -r R9000 -x /cgi-bin -t 70 -
8081 root 876 S /usr/sbin/uhttpd -h /www -r R9000 -x /cgi-bin -t 70 -
8083 root 44 S inetd
8119 root 276 S acld
8120 root 68 S aclhijackdns
8307 root 48 S /usr/bin/hd-idle -i 1800
8447 root SW [ telnetDBGD ]
8448 root SW [ acktelnetDBGD ]
8449 root SW [checkSBusTimeou]
8451 root SW [NU TCP]
8452 root SW [NU UDP]
8453 root 160 S /sbin/KC_BONJOUR
8454 root 96 S /sbin/KC_PRINT
8542 root 48 S potval
8590 root SW< [vport-mii]
8781 root 244 S /sbin/traffic_meter
8826 root 48 S /usr/sbin/telnetenable
8863 root 440 S /bin/sh /sbin/11ad_linkloss_wd.sh
8942 root 244 S /usr/sbin/ntgrddns -c /tmp/ntgrdns.conf
9741 root 540 S /usr/sbin/dbus-daemon --system
9748 root 1008 S avahi-daemon: registering [R-Home.local]
10157 root SW [kworker/0:2]
10206 root 1208 S N /usr/sbin/afpd -F /etc/netatalk/afpd.conf -P /var/run
10451 root 424 S /bin/sh /usr/sbin/check_time_machine
11846 root SW [kworker/1:0]
13151 root 364 S /opt/xagent/xagent -w -d --ca_file /opt/xagent/certs/
13153 root 2080 S /opt/xagent/xagent -w -d --ca_file /opt/xagent/certs/
18507 root 108 S sleep 60
19288 root 440 S /bin/sh /sbin/fan_on_off 80 70 90 80 90 80 85 70 85 7
19487 root SW [kworker/2:0]
19957 root 108 S sleep 60
20766 root 112 S sleep 5
20840 root SW [kworker/3:0]
20985 root 108 S sleep 1
21110 root 740 S /usr/sbin/net-cgi
21117 root 356 S /bin/sh -c /sbin/enable_collect_console_log.sh >/dev/
21121 root 356 S /bin/sh /sbin/enable_collect_console_log.sh
21123 root 360 S /bin/sh /sbin/basic_log.sh
21125 root 360 S /bin/sh /sbin/console_log.sh
21126 root 360 S /bin/sh /sbin/wireless_log.sh
21127 root 424 S /bin/sh /sbin/capture_packet.sh
21135 root 112 S sleep 1
21150 root 360 R ps
21155 root 112 S sleep 300
21160 root sleep 300
21163 root sleep 300
21165 root sleep 300
21166 root 356 S sh -c /usr/sbin/ethtool eth0 |grep "Duplex"|cut -d :
24182 root SW [kworker/0:1]
28495 root 276 S syslogd -m 0 -T GMT+8 -c 1083
32078 root 336 S pppd call dial-provider updetach
32118 guest 408 S /usr/sbin/dnsmasq --except-interface=lo -r /tmp/resol
total used free shared buffers
Mem: 1030732 216296 814436 0 10416
Swap: 0 0 0
Total: 1030732 216296 814436
nameserver 192.117.235.237
nameserver 62.219.186.7
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default bzq-179-37-1.cu 0.0.0.0 UG 0 0 0 ppp0
192.168.9.0 * 255.255.255.0 U 0 0 0 br0
192.168.10.0 * 255.255.255.0 U 0 0 0 tun0
212.179.37.1 * 255.255.255.255 UH 0 0 0 ppp0
239.0.0.0 * 255.0.0.0 U 0 0 0 br0
IP address HW type Flags HW address Mask Device
192.168.9.228 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.6 0x1 0x0 00:15:65:98:1d:ab * br0
192.168.9.249 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.243 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.214 0x1 0x2 00:50:56:94:fb:0d * br0
192.168.9.29 0x1 0x0 00:34:da:8a:29:52 * br0
192.168.9.245 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.8 0x1 0x0 f8:16:54:cb:79:2e * br0
192.168.9.229 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.7 0x1 0x2 b8:86:87:48:dc:a3 * br0
192.168.9.4 0x1 0x2 f0:99:bf:31:35:da * br0
192.168.9.252 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.30 0x1 0x0 00:34:da:8a:29:52 * br0
192.168.9.241 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.246 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.100 0x1 0x2 98:90:96:dc:37:26 * br0
192.168.9.50 0x1 0x2 00:0c:29:11:eb:b4 * br0
192.168.9.234 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.155 0x1 0x2 02:ba:d0:88:10:20 * br0
192.168.9.9 0x1 0x2 00:ff:5f:2c:47:59 * br0
192.168.9.230 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.251 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.5 0x1 0x0 5c:a3:9d:41:8e:b4 * br0
192.168.9.248 0x1 0x2 98:90:96:b8:af:8e * br0
192.168.9.211 0x1 0x2 00:0c:29:0f:8d:d8 * br0
192.168.9.253 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.31 0x1 0x2 00:34:da:8a:29:52 * br0
192.168.9.136 0x1 0x2 00:0c:29:e6:13:0a * br0
192.168.9.28 0x1 0x0 00:34:da:8a:29:52 * br0
192.168.9.247 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.244 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.235 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.232 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.10 0x1 0x2 fc:92:3b:f4:01:00 * br0
192.168.9.231 0x1 0x0 00:00:00:00:00:00 * br0
192.168.9.144 0x1 0x2 00:0c:29:2c:31:ec * br0
