rusman
May 28, 2017Tutor
R9000 block ssl-vpn connection ( port 443)
Hi All, i have issue with connecting to SSL VPN on port 443, i have R9000 router, i use firmware v1.0.1.36 When i tryed to connect to my work with Cisco Anyconnect that use port 443 i get denied....
- Jun 02, 2017
Hi All,
Just to Update,
Reload the router and SSL VPN worked correctly.
May be was some issue with MTU like TheEther say...
Will continues to monitor if it will happen again will update.
Thanks for you all for trying to help.
Ruslan.
May 30, 2017Guru - Experienced User
Are you using a VPN service or VPN application? Might contact either Mfr of these service for additional help and info. Seems this maybe a VPN service/app issue possibly.
rusman
May 31, 2017Tutor
Hi FURRYe38,
Yes i use VPN applicaton Cisco Anyconnect.
i manage the remote peer,
like i wrote without R9000 the connection worked ok.
i forgot to wrote also when i trying to browse to this vpn https://XX.XX.XX.XX netgear recognize this like DDOS and blocking the connection.
Thanks for trying to help,
Ruslan.
