rusman
May 28, 2017Tutor
R9000 block ssl-vpn connection ( port 443)
Hi All, i have issue with connecting to SSL VPN on port 443, i have R9000 router, i use firmware v1.0.1.36 When i tryed to connect to my work with Cisco Anyconnect that use port 443 i get denied....
- Jun 02, 2017
Hi All,
Just to Update,
Reload the router and SSL VPN worked correctly.
May be was some issue with MTU like TheEther say...
Will continues to monitor if it will happen again will update.
Thanks for you all for trying to help.
Ruslan.
TheEther
May 31, 2017Guru
Feel free to run it. If it looks the same as the last one, there's no need to post it. Do you have another router that you could test?
If you want to put the pcap files some place that I can access, I can take a look.
rusman
Jun 02, 2017Tutor
Hi All,
Just to Update,
Ruslan.
