Oterwill
Jan 11, 2022Aspirant
R9000 BTTV IGMP Configurarion
I have an R9000 and connect it straight to the openreach modem on the wall. I have FTTP from BT and I have BTTV. in my WAN settings I do have “ support british telecom (bt) igmp proxying.” And all my ...
Jan 11, 2022Guru - Experienced User
Oterwill
V1.0.5.38
Yes. Done a reset on it and started from scratch when it wasn’t working at first.
- FURRYe38Jan 12, 2022Guru - Experienced User
Had this worked before while using any other prior versions of FW or is this the first time this has started?
- OterwillJan 12, 2022AspirantFirst time. Only just got BT FTTP and BTTV this week. Works fine using my own router except for this snaggle. Was on Virgin previously.
Something you should contact NG support about and let them know what your seeing.
You might give voxels FW a try:
