Oterwill
Jan 11, 2022Aspirant
R9000 BTTV IGMP Configurarion
I have an R9000 and connect it straight to the openreach modem on the wall. I have FTTP from BT and I have BTTV. in my WAN settings I do have “ support british telecom (bt) igmp proxying.” And all my ...
Oterwill
V1.0.5.38
Yes. Done a reset on it and started from scratch when it wasn’t working at first.
Jan 12, 2022Guru - Experienced User
Had this worked before while using any other prior versions of FW or is this the first time this has started?
- OterwillJan 12, 2022AspirantFirst time. Only just got BT FTTP and BTTV this week. Works fine using my own router except for this snaggle. Was on Virgin previously.
- FURRYe38Jan 12, 2022Guru - Experienced User
Something you should contact NG support about and let them know what your seeing.
You might give voxels FW a try:
