b5gvjmdxdi
Oct 10, 2017Aspirant
R9000 dropping LAN connection entirely after a while
I am having a similar problem to this thread but I can't reply there for some reason, so I'm starting a new thread. I have the R9000 X10 with the 1.0.2.40 firmware (latest from Netgear site as of th...
ElaineM
Oct 11, 2017NETGEAR Employee Retired
Welcome to the community, b5gvjmdxdi
Have you tried resetting the router after firmware update?
It seems that the DHCP is the problem.
Did you try downgrading the firmware of the router?
- b5gvjmdxdiOct 12, 2017Aspirant
Hi,
It looks like disabling the DoS protection stabilized the router. So I guess the DoS protection might falsely be detecting a DoS from inside the network or something - I am not sure.
- ElaineMOct 12, 2017NETGEAR Employee Retired
Let's observe your connection for another 24hrs to see if it's resolved.
- ElaineMOct 16, 2017NETGEAR Employee Retired
Are you still having issues?
- b5gvjmdxdiOct 26, 2017Aspirant
The router stops responding to individual hosts about once a week since disabling the DoS protection, but it still happens. Rather than it dropping once every 10-15 hours, it's now once a week, give or take.
Better, but still pretty unreliable.
