b5gvjmdxdi
Oct 10, 2017Aspirant
R9000 dropping LAN connection entirely after a while
I am having a similar problem to this thread but I can't reply there for some reason, so I'm starting a new thread. I have the R9000 X10 with the 1.0.2.40 firmware (latest from Netgear site as of th...
ElaineM
Oct 11, 2017NETGEAR Employee Retired
Welcome to the community, b5gvjmdxdi
Have you tried resetting the router after firmware update?
It seems that the DHCP is the problem.
Did you try downgrading the firmware of the router?
b5gvjmdxdi
Oct 12, 2017Aspirant
Hi,
It looks like disabling the DoS protection stabilized the router. So I guess the DoS protection might falsely be detecting a DoS from inside the network or something - I am not sure.
- ElaineMOct 12, 2017NETGEAR Employee Retired
Let's observe your connection for another 24hrs to see if it's resolved.
- ElaineMOct 16, 2017NETGEAR Employee Retired
Are you still having issues?
- b5gvjmdxdiOct 26, 2017Aspirant
The router stops responding to individual hosts about once a week since disabling the DoS protection, but it still happens. Rather than it dropping once every 10-15 hours, it's now once a week, give or take.
Better, but still pretty unreliable.
- b5gvjmdxdiOct 28, 2017Aspirant
It happened twice yesterday. Appears to be loosely correlated to activity and volume of traffic. On days when I'm home and using my internet a lot, it drops out about once every 8-10 hours. On days when I'm away from home, it may take 4 or 5 days or even more before it drops.
Manually setting one of my computers to: static IP, netmask 255.255.255.0, default gateway 192.168.1.1, DNS servers 8.8.8.8 and 192.168.1.1, still doesn't work after it drops out.
This is a very serious problem with 1.0.2.40, please fix!
