B4D_WOLF
Sep 21, 2018Guide
R9000 DROPPING WIFI EVERY 15-20 MINS
Neatgear Nighthawk R9000 X10
Firmware V1.0.4.12
QoS is already turned off (was never set up)
Wifi randonly drops off for about 30 secs about every 15-20 mins. This is mostly noticable on the 2....
- Sep 30, 2018
Update:
Nothing I tried fixed the issue and I got really tired of spending so much time trying to fix it that I returned it and made a switch to a different brand...
isaki
Sep 28, 2018Apprentice
I have had constant WiFi problems since upgrading to 1.0.4.12. I'm hoping it is just the firmware.
isaki
Sep 30, 2018Apprentice
I had a BestBuy replacement plan for my R9000. So, I decided to exchange it (I was only seeing drops on 5GHz; 2.4 and ethernet were both fine). The replacement R9000 works flawlessly. It is possible you are seeing hardware issues.
