B4D_WOLF
Sep 21, 2018Guide
R9000 DROPPING WIFI EVERY 15-20 MINS
Neatgear Nighthawk R9000 X10
Firmware V1.0.4.12
QoS is already turned off (was never set up)
Wifi randonly drops off for about 30 secs about every 15-20 mins. This is mostly noticable on the 2....
- Sep 30, 2018
Update:
Nothing I tried fixed the issue and I got really tired of spending so much time trying to fix it that I returned it and made a switch to a different brand...
Prodigalgenius
Dec 17, 2018Aspirant
so just pm christine for the beta link? coz I never had this issue for the first 2 months but now..this is recurring every hr. although it comes back after 1-2 mins. still im disconnected. I have multiple routers designated by purpose but this one is my main one considering this is damn expensive and I expect the best from this..I'm always a netgear user I can't believe this is happening to my most expensive router. i never had this issue with my r7000s even my ex7000 and 7800. this is ridiculous I have to move all my automation hub away from this router to my ex7000 which is hooked up directly to my att fiber router. this is frustrating.
Aggie94
Just curious. I never see the fan inside of the r9000 turn. Is this typical? I put my hand over the top of the router and it is is pretty cool to warm but never hot. I just use it for interney and my home automation devices, so I don't game with the router.
- SkimPappaDec 17, 2018ApprenticeMy fan didn’t run much either. I adjusted the temps down on the debug screen so they always run.
http://routerlogin.net/debug.htm
