mak1965
Apr 25, 2018Follower
R9000 Extension Antenna
Hi,
I am wondering about using and extension antenna on my X10 Router. I had a Nighthawk 7000 and it was easy, I unscrewed the stock antenna, and screwed in an amplified antenna to that socket. Is...
Lewisstructure
Jan 31, 2023Aspirant
Yes, can the NightHawk X10 R9000 Antennas’s be removed or use extender antennas to it?
- FURRYe38Jan 31, 2023Guru - Experienced User
If you don't see any kind of screw or finger/thumb turning ring on the end of the antenna closest to the router case, then no, you can't remove those.
