frazipe1
Feb 24, 2018Tutor
R9000 Firmware 1.0.3.6 and 1.0.3.10 problems
I installed the 1.0.3.6 firmware update a few days ago and everything seemed fine but yesterday I went to play a movie on Plex and it said the server was offline. I've had this issue before where my ...
- Feb 25, 2018
Both USB drives are still workable? Blamed Netgear recently for breaking ReadySHARE on my X10 some days before the 1.0.3.10 build was officially releaed - and discovered one of the two USB HDD was going west.
schumaku
Feb 24, 2018Guru - Experienced User
Factory reset ... use the button and/or the Web UI ... an re-configure from scratch.
- frazipe1Feb 25, 2018Tutor
I reset to factory setting using the Web UI and when it comes back up it automatically has the 1.0.3.10 version installed and is doing the same thing. Before I waste my time, does it do the same thing if I reset using the button?
