DoundMix
Oct 26, 2019Tutor
R9000 firmware 1.0.5.2
I updated my router to the latest firmware 1.0.5.2. Soon my Synology NAS (214+) sent me an email stating, there is a problem configuring ports and UPnp. I tried to manually configure the NAS but i...
- Nov 02, 2019
Latest download works.
fercho1974
Oct 28, 2019Guide
Thanks for the info.
Can you clarify......is it just the UPnP port forwarding that is failing? Can you still access the NAS internall from a client internal to your LAN?
Was that the only issue? Based on the track record with Netgear's firmware and lack of QA / regression testing, I am always hesitant to upgrade. But my security hat tells me to stay current to remediate vulns that exist. So, Im torn at the moment.
DoundMix
Oct 28, 2019Tutor
All ports fail .
- ramzevaOct 29, 2019Aspirant
all my wired connections when offline with this update, only wireless is working currently.
- mingle123Oct 29, 2019Tutor
Does your wired client can access R9000 or not? how about reboot?wired device become offline is strange, maybe you need to check your ip address and use a static ip to check
- DoundMixOct 29, 2019Tutor
Reboots do not work Only previous firmware works. The new firmware only breaks the Synology Nas port forwarding rules. Everything else works. So, no media streaming, local or remote.
