DoundMix
Oct 26, 2019Tutor
R9000 firmware 1.0.5.2
I updated my router to the latest firmware 1.0.5.2. Soon my Synology NAS (214+) sent me an email stating, there is a problem configuring ports and UPnp. I tried to manually configure the NAS but i...
- Nov 02, 2019
Latest download works.
JRockrohr
Nov 03, 2019Initiate
After updating to firmware version 1.0.5.2 thinnet client could no longer get address from DHCP. Shows up on device list with address 0.0.0.0. Other connections worked fine. Went back to previous version and Wyse 3040 thinnet client works fine.
- mingle123Nov 05, 2019Tutor
what's thinnet client? wired or wireless? does static ip works? change connect port maybe help
- JRockrohrNov 05, 2019InitiateGoogle it.
Otherwise known as a "thin client. Virtual computer, no local hard drive, always wired, always connected secure home computer connection for work. Must obtain address from DHCP.
Actual unit:
Dell Wyse 3040, its smallest, yet still powerful, thin client to date. Size wise, it is only 1.1 inches tall, 3.75 inches wide and deep, and weighs 0.53lbs. Though diminutive in size, the 3040 sports an Intel Atom X5 1.44GHz quad-core processor that supports up to 2GB DDR3 RAM and 8GB flash.
