Ak74
Nov 15, 2021Tutor
R9000 firmware update 1.0.5.38 broke web ui
After firmware update to 1.0.5.38 router's web UI is broken
Nov 15, 2021Guru - Experienced User
I'd start with a reboot and trying a different web browser.
If that doesn't help. then I'd try factory resetting.
- Ak74Nov 15, 2021Tutor
Yeah, rebooted and tried Google Chrome, Firefox and Vivaldi - no luck.
Not comfortable resetting to factory right away, i changed few thing time back not sure what they were, but somethign with channels not to intersect with neighbour's routers )
- plemansNov 15, 2021Guru - Experienced User
do you have a hardwired device you can connect and test? If its not working wired, it won't matter if you change wireless channels.
It works when wired and wireless it's just web ui that is stuck, NIGHTHAWK app can connect to it though.. wierd
