Ak74
Nov 15, 2021Tutor
R9000 firmware update 1.0.5.38 broke web ui
After firmware update to 1.0.5.38 router's web UI is broken
Nov 15, 2021Guru - Experienced User
I'd start with a reboot and trying a different web browser.
If that doesn't help. then I'd try factory resetting.
Ak74
Nov 15, 2021Tutor
Yeah, rebooted and tried Google Chrome, Firefox and Vivaldi - no luck.
Not comfortable resetting to factory right away, i changed few thing time back not sure what they were, but somethign with channels not to intersect with neighbour's routers )
- plemansNov 15, 2021Guru - Experienced User
do you have a hardwired device you can connect and test? If its not working wired, it won't matter if you change wireless channels.
