Ak74
Nov 15, 2021Tutor
R9000 firmware update 1.0.5.38 broke web ui
After firmware update to 1.0.5.38 router's web UI is broken
Ak74
Nov 15, 2021Tutor
Yeah, rebooted and tried Google Chrome, Firefox and Vivaldi - no luck.
Not comfortable resetting to factory right away, i changed few thing time back not sure what they were, but somethign with channels not to intersect with neighbour's routers )
Nov 15, 2021Guru - Experienced User
do you have a hardwired device you can connect and test? If its not working wired, it won't matter if you change wireless channels.
- Ak74Nov 15, 2021Tutor
It works when wired and wireless it's just web ui that is stuck, NIGHTHAWK app can connect to it though.. wierd
- plemansNov 15, 2021Guru - Experienced User
About all I'd recommend is the factory reset or downgrading the firmware and seeing if it fixes it.
- CelpowNov 23, 2021Initiate
Almost the same problem here, sometimes during the day ( between 5 and 10 times), i can't acess to internet and when i tied to connect to the R9000 web ui interface, i have the same thing as you.
I've tried to reset it but no luck; i'm going to reinstall the old firmware
