dave4925's avatar
dave4925
R9000 Firmware V1.0.2.32 release note details about "security updates"
The release notes to V1.0.2.32 just say "security updates"
I was wanting to know which security issues were updated in this version?
I am very concerned about whether or not this patches the sambacry vulnerability that is in the wild now.
Thanks!
  • dave4925 wrote:
    Do you know what version of SAMBA the R9000 uses in its latest firmware, and if it has been tested against the sambacry exploit?
    Plese re-read my reply above.
    dave4925 wrote:
    Also, a verbose security update list would be great.
    Agree.
  • schumaku's avatar
    schumaku
    The R9000 V1.0.2.32 does run SAMBA Version 3.0.24 (I'm not kidding - with plenty of other probably less critical vulnerabilities and non-required restrictions in the year 2017...) like many other Netgear Nighthawk and other Netgear routers. As per the CVE-2017-7494 , SAMBA versions before v3.5.0 are said not to be vulnerable. The Netgear implemented SAMBA version is decades old, not just seven years as when this bug was introduced...
    Don't worry - there are many more security issues neither patched nor the configurations changed. I strongly advice not to expose the R9000 (or any other Netgear router) for remote management, for ReadySHARE by http, https, or ftp th the Internet.
    • dave4925's avatar
      dave4925
      Thanks!
      • schumaku's avatar
        schumaku
        Agree.
