LosGatos17960
Jul 03, 2021Aspirant
R9000 Firmware V1.0.5.28 Plex Not available for Remote Access
After upgrading to Nighthawk V9000 Firmware V1.0.5.28, and running Plex 1.19.5.3112 Sept 29, 2020 - Remote access stopped working. I had manually specify a public port checked. The default port ...
kthejoker202
Jan 03, 2022Aspirant
This is still an issue with the current firmware.
The only fix for this is to downgrade to version 1.0.2 and then it is accessible outside the network.
CAN SOMEONE PLEASE FIX THIS FIRMWARE FOR THE LOVE OF GOD.
LosGatos17960
Try manually setting the outgoing port. The default port doesn't work, but when I manually set an outgoing port, it worked for me.
- kthejoker202Jan 03, 2022Aspirant
I did, I tried a bunch of ports, and canyouseeme.org even says timed out.
But downgrading to 1.0.2 fixed it.
This is definately an issue with the firmware. I've done a huge google search and many are having this problem.
