schonkeren
Oct 22, 2022Tutor
R9000 horrible throughput and no telnet nor web interface to reset to another firmware (1.0.5.42)
NETGEAR Router R9000 gives:
| FW Version : | V1.0.5.42 |
| Series number : | Deleted for security reasons |
| Wireless Region : | Europe |
Since I recently upgraded to that firmware, I noticed streaming had become really bad. After some bandwidth tests I noticed I'd go from less than 1Mb down to >300Mb down, fluctuating over and over again.
I'm pretty sure the router's new firmware is to blame. Loading the web interface is really slow, logging in even slower and loading the actual settings overview just won't load at all. At best, I get the left column with the options. Trying to click advanced etc etc etc won't do anything. All I get in the main page is:
Please wait a moment...
So I tried to telnet to the router. That fails too. I don't think the R9000 still works with the EnableTelnet.exe tool:
telnetenable 192.168.10.1 B0B06A1BF1A0 admin mysecretpwd
Payload has been sent to Netgear router.
Telnet should be enabled.
When I telnet 192.168.10.1, I get an error that the connect failed. I used 'arp -a' to verify that the MAC address I used is correct.
I am connected through wifi with the 5GHz network. I have not tested with a LAN cable. I think that would fail too.
http://192.168.10.1/setup.cgi?todo=debug fails too (192.168.1.1 is my ISP router. Its wifi, while not as strong, works as expected and more importantly, has a stable bandwidth)
SO... What do I do now? Throw the router away? 😞
Well I'll be damned! After trying to fully load the web interface well over 6 hours today, I suddenly find the webinterface loading just fine! I haven't changed anything (there was no way I could). All I did since I last posted, was the
telnetenable2 192.168.10.1Deleted for security reasons admin mypassword
Nothing else was done by me. It now suddenly just loads. Telnet itself still fails, as it should.
After I logged in just now, I got an "updating interface language settings..." progress bar (instead of the original "Please wait a moment..." message with the rotating loading circle...).
I'll keep everything as-is, see if the bandwidth problems are now solved too. I now also have a fresh backup of my settings, so a full reset won't hurt as much 🙂
PS: I hate that the nighthawk app can't backup settings nor upload a new firmware. Seems like a huge miss.
Thanks for now, I'll update any findings I might have.
PS:
fails too
After you update, did you try a factory reset? that might help the speed issue.
The telnet option has been getting pulled from a lot of netgear devices. If its something you need, you can downgrade the firmware to the prior generation's firmware.
Thanks, yeah I'd like to make a backup of my settings first (there are a lot of them), but I cannot because the webinterface just won't properly load. It's not a configuration error. I guess I'll have to force a hard reset then and set everything up from scratch, including all my rules. Frack 😞 It better work! 🙂
PS: telnetenable2 didn't work either. As confirmed by you guys, telnet can't be enabled any longer in this manner. So I'll let go of that idea 🙂
FW Version : V1.0.5.42 Series number : Deleted for security reasons Wireless Region : Europe Since I recently upgraded to that firmware, I noticed streaming had become really bad. After some bandwidth tests I noticed I'd go from less than 1Mb down to >300Mb down, fluctuating over and over again.
Two things to try:
- Reset the device and set it up from scratch
- Roll back to previous firmware
I don't know what you expect to do with Telnet. Netgear has been disabling it with newer firmware, for security reasons.
If you are trying to apply new firmware, what's wrong with the manual approach?
This bit is puzzling, and not just because it is hard to follow.
Where does this http://192.168.10.1/ come from?
And what is this "192.168.1.1 is my ISP router"?
Are you saying that you have a router in front of your R9000 router? That's a famously bad idea that invites problems.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
