augsy
Dec 04, 2021Follower
R9000 invalid serial number after factory reset
After factory reset, I entered the "serial number" from the router and the pop up says invalid. Appreciate if someone can help solve the issue.
1 Reply
You shouldn't need the serial number.
If you factory reset it, your default info is:
login: admin
password: password
all lower case. you should be able to use that to log into it and change the loging password
