alternet
Nov 27, 2020Tutor
R9000 is rebooting several times a day without any known reason
Hi all, I do have a problem with my R9000 which is rebooting several times a day without known to me reason. Checking the log, I can see only the information from the moment it started up then f...
- Dec 01, 2020
Have you tried downgrading the firmware a version? maybe the one you're on has a bug/issue
alternet
Nov 27, 2020Tutor
it seems the screened log is not loaded properly:
here we go again in TXT format (+GDPR encryption :smileylol: ) this time:
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:18:53
[DoS Attack: ACK Scan] from source: 31.xxx.48, port 5222, Friday, November 27, 2020 20:18:39
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:18:23
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:17:57
[DHCP IP: 11.1.1.4][Device Name: ] to MAC address e8:xxx23, Friday, November 27, 2020 20:17:56
[DHCP IP: 11.1.1.4][Device Name: ] to MAC address e8:xxx23, Friday, November 27, 2020 20:17:55
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:17:54
[DHCP IP: 11.1.1.4][Device Name: ] to MAC address e8:xxx:23, Friday, November 27, 2020 20:17:53
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:17:52
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx0e, Friday, November 27, 2020 20:17:39
[DoS Attack: RST Scan] from source: 54.xxx190, port 443, Friday, November 27, 2020 20:17:38
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:17:38
[DoS Attack: ACK Scan] from source: 162.xxx.234, port 443, Friday, November 27, 2020 20:17:38
[DoS Attack: ACK Scan] from source: 103.xxx.177, port 443, Friday, November 27, 2020 20:17:38
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:16:12
[DoS Attack: ACK Scan] from source: 149.xxx.153, port 443, Friday, November 27, 2020 20:15:33
[DoS Attack: ACK Scan] from source: 31.xxx.48, port 443, Friday, November 27, 2020 20:15:12
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx:0e, Friday, November 27, 2020 20:14:50
[DoS Attack: ACK Scan] from source: 149.xxx153, port 443, Friday, November 27, 2020 20:14:29
[DHCP IP: 11.1.1.7][Device Name: CHROMECAST-ULTRA] to MAC address 54:xxx0e, Friday, November 27, 2020 20:14:14
[DoS Attack: ACK Scan] from source: 31.xxx.48, port 443, Friday, November 27, 2020 20:14:06
[UPnP set event: add_nat_rule] from source 11.1.1.14, Friday, November 27, 2020 20:14:02
[PLEX]You USB Drive for plex libary has removed, Friday, November 27, 2020 20:13:45
[DHCP IP: 11.1.1.3][Device Name: ] to MAC address 5cxxx5a, Friday, November 27, 2020 20:13:40
[admin login] from source 11.1.1.17, Friday, November 27, 2020 20:13:37
[USB device attached] The USB storage device SanDisk Ultra Fit(new is attached to the router, Friday, November 27, 2020 20:13:36
[PLEX]You USB Drive for plex libary has removed, Friday, November 27, 2020 20:13:36
[DoS Attack: ACK Scan] from source: 31.xxx.48, port 443, Friday, November 27, 2020 20:13:30
[Plex Net]No Network Device connect, exit, Friday, November 27, 2020 20:13:25
[DoS Attack: ACK Scan] from source: 149.xxx.153, port 443, Friday, November 27, 2020 20:13:25
[Time synchronized with NTP server] Friday, November 27, 2020 20:13:22
[Initialized, firmware version: V1.0.5.24] Friday, November 27, 2020 20:13:20
