alternet
Nov 27, 2020Tutor
R9000 is rebooting several times a day without any known reason
Hi all, I do have a problem with my R9000 which is rebooting several times a day without known to me reason. Checking the log, I can see only the information from the moment it started up then f...
- Dec 01, 2020
Have you tried downgrading the firmware a version? maybe the one you're on has a bug/issue
Nov 28, 2020Guru - Experienced User
try doing a reinstall of the firmware. do it over a hardwired connection. Afterwards, factory reset the router and do a clean reinstall (not from backup).
I'd also leave your chromecast off for a period. See how stable the router is after that.
- alternetDec 01, 2020Tutor
Hi plemans,
I have followed your advice I after the reset and reload of the firmware I notice about twice less reboots then previously - but it still restarting without any known to me reason.
Seems, it is for change,
Thanks
/me
- plemansDec 01, 2020Guru - Experienced User
