Grifter77
Jan 03, 2019Aspirant
R9000 Nighthawk Randomly looses signal in 2.4 but not 5
I have a R9000 AD7200Smart Wifi router and have hgad nothing but issues since I got this thing.
I have a Fiber internet going straight into the router and use a few lan connections but mainly Wifi ...
- Jan 03, 2019
Dropping connections has been reported by a number of people, and there are numerous threads about dropping connections after "upgrading" to 1.0.4.12. You can either go back to a previous firmware version, or request to be included in the beta firmware test group, and use Netgear's beta firmware.
I had a lot of dropout probems with 1.0.4.12, but I am getting really good results with the latest beta firmware (v1.0.4.26).
SScandy
Jan 03, 2019Luminary
Grifter77
I cant remeber how to downgrade firmware I have done it in the past is there a link or walk through on doing this?
- antinodeJan 03, 2019Guru
> I cant remeber how to downgrade firmware [...]
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
