RD_R9000's avatar
RD_R9000
Initiate
Nov 02, 2021
R9000 Nighthawk X10 AD2700 Smart WiFi Unable to login into Router after attempting an update
I attemped and update from mt iPhone using the Nighthawk app and after the attemped update the Router is unable to function. No WiFi conection or ethernet conection. Anybody experince this issue and if so is there a fix for it? Thanks,RD_R9000
  • plemans's avatar
    On the forum, we usually recommend users update via a hardwired connection. Reason why is if we see issues with firmware updates, its when its done over the app or over wifi.
    things you can try?
    Try factory resetting. Push and hold reset for up to 30 seconds while powered on.
    doesn't work?
    You can try recoving it with tftp or nmrpflash.
    are you on windows? if so, follow this guide
    https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
    just make sure you enable tftp
    https://www.thewindowsclub.com/enable-tftp-windows-10
    and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
    https://www.youtube.com/watch?v=R9DLrLQrpaw
    and if that doesn't work, you can try using nmrpflash
    https://github.com/jclehner/nmrpflash
    • RD_R9000's avatar
      RD_R9000
      Initiate
      Hey plemans Guru, thanks for the reply and tips and instructions. I will for sure give it a try and post my results either way. I’ve owned this Router since 12/2018 and this is The very first issue I’ve had with it.
      Thanks again and be blessed…
      RD_R9000
      • plemans's avatar
        Good luck!
        Take your time with both tftp/nmrpflash. Both are sensitive to timings and spelling. So if it doens't work the first time, check your work and try again
