Nuforce
Nov 20, 2023Aspirant
R9000 Nighthawk X10 Router SFP internet port question
Hi I want to be able to use the X10 as a bridge to connect to my existing wireless network. I also want to connect a device I have to the router via the SFP port. Will the SFP port output acc...
Nov 20, 2023Guru - Experienced User
I've not tried this with mine however I presume it should be enabled and work while in wireless brige mode. Something to try if you have a SFP to ethernet adapter plugged in while in wireless bridge mode and see.
I'd set up the router with a ethernet connection to one of the regular LAN Ports first, then test after that.
