Nuforce
Nov 20, 2023Aspirant
R9000 Nighthawk X10 Router SFP internet port question
Hi I want to be able to use the X10 as a bridge to connect to my existing wireless network. I also want to connect a device I have to the router via the SFP port. Will the SFP port output acc...
schumaku
Nov 20, 2023Guru - Experienced User
Yes, this is named as Access Point mode. How do I change my NETGEAR router to AP mode?
I think he wants to configure the router for wireless bridge mode...and act as a wireless client then connect a wired PC to the SPF port using a SFP to ethernet converter...
- schumakuNov 20, 2023Guru - Experienced User
There is no wireless client mode available on most (if not all, the exception are few vey old models) Netgear Routers allow to make it a wireless bridge member.
- FURRYe38Nov 20, 2023Guru - Experienced User
There is on the R9000. The R7000 and R7800 also has this mode.
If true, there are several more models supporting this again: NETGEAR Support What is wireless bridge mode and how do I set it up on my NETGEAR router?
