LukeBAus
Jan 26, 2022Tutor
R9000 No Ethernet Connectivity
Hi All, Recently in the last few weeks I upgraded to firmware V1.0.5.38 and I for some reason my devices connected via a wired connection drop out after a short amount of time and I need to reboot t...
- Jan 30, 2022
So issue was I had a device connected that was doing some kind of broadcast somehow and took down all wired devices!
Previously this device was in a connected state and configured, I recently done a factory reset on it and it was attached and not configured.
Anyhoo all good now! Thanks for the support all.
Jan 26, 2022Guru - Experienced User
whenever you have issues after a firmware change, the first step is usually a factory reset. Sometimes old/bad settings can cause issues.
Have you tried this?
