LukeBAus
Jan 26, 2022Tutor
R9000 No Ethernet Connectivity
Hi All, Recently in the last few weeks I upgraded to firmware V1.0.5.38 and I for some reason my devices connected via a wired connection drop out after a short amount of time and I need to reboot t...
- Jan 30, 2022
So issue was I had a device connected that was doing some kind of broadcast somehow and took down all wired devices!
Previously this device was in a connected state and configured, I recently done a factory reset on it and it was attached and not configured.
Anyhoo all good now! Thanks for the support all.
michaelkenward
Jan 27, 2022Guru - Experienced User
LukeBAus wrote:
My PC states the connection is established but to an unidentified network.
This is a Windows PC?
Try running the Network Troubleshooter in Windows.
Start here:
Fix network connection issues in Windows 10
What is the modem/gateway (make/model) in front of your router?
- LukeBAusJan 30, 2022Tutor
- michaelkenwardJan 30, 2022Guru - Experienced User
Ouch. Nice work, Sherlock.
Was this something that anyone else is likely to come across?
