redmanh's avatar
redmanh
Follower
Nov 27, 2023
r9000 no wifi (ethernet works)
I have an issue right now with my router. Just started this morning where the ethernet works. The ps4 is plugged in and we can stream and use the internet. The wifi isn't on and I can figure out what ...
  • plemans's avatar
    Nov 28, 2023
    Did you push and hold the wifi on/off button for at least 2 seconds?
