hgpilot55
Nov 29, 2017Star
R9000 not allowing some wired devices to connect
My R9000 has been working great for months but over the last 2 days all of my Sonos devices (all hard wired to the network) have stopped working. Nothing about my configuration has changed - no R9000 firmware updates - these devices have all stopped working. They show up under the Netgear Admin Portal / Advanced / Security / Access Control list of "allowed devices not currently connected to the network" - yet none of them are connected. I removed all of them from this list and then unplugged / restarted each device - they slowly start appreaing on this "not connected" list which tells me the R9000 gives them a DHCP address but for some reason they aren't connecting. They are the only devices that aren't connected - all other wired devices work. Maybe this is a Sonos thing?
Hi hgpilot55,
If you change ports will it show the same problem?
Try disabling the access control first if it will work.
