pnaralove
Jul 30, 2024Aspirant
R9000 not booting up
Nighthawkk X10 (R9000) AD 7200 Smart Router Suddenly, the route stopped working and the following is the LED blinking status. 1. The following LED is blinking white Power Internet USB3.0 1...
pnaralove
I don't know the exact firmware version.
Nothing is plugged in any port.
Based on network adaptor property from Windows control panel, every port says Cable unplugged.
As a result, I can't access Web GUI.
Also I tried to reset many times but nothing happens when I press reset button.
Jul 30, 2024Guru - Experienced User
Try a 30-30-30 reset and see if this clears this...
Disconnect the router from the ISP modem and all ethernet connected devices before hand.
