xxjahasotoxx
Feb 26, 2018Aspirant
r9000 port forwarding
hello I'm having trouble forwarding ports on a r9000 I'm trying to forward ports for Nvidia game stream I've gone through the steps to manually forward the ports and have even shut off any firewals t...
- Mar 01, 2018
turns out it might have either been a bug with my windows 10 install or even the nvidia software it self I reinstalled windows along with the Nvidia Geforce software and it worked thanks for the help
antinode
Feb 28, 2018Guru
> [...] Then to actually PF [...]
It sounds plausible, although copy+paste of the actual
port-forwarding rules table would be more trustworthy than your
description.
> on my local connection it works fine
What, exactly, does that mean? What is "it"?
> another way i know the service is running is because i can see the
> service on my local network.
What, exactly, does that mean? "see" what, how?
> Is there anything else I could try to diagnose the issue?
One potentially useful tool would be the Telnet client which is built
into Windows:
Settings > Apps > (Related settings) Programs and Features >
Turn Windows features on or off : Telnet Client
Once enabled, this can be used to test a (TCP) connection to the
server/port of your choice:
telnet <server_IP_address> <port>
If anyone is listening at that port, then the Telnet client should
connect. If that works when using the server's LAN IP address, then try
the router's WAN IP address (from within the LAN). (This depends on a
router feature, "NAT loopback", which should work.)
> all the port checking sites and IP sites give my routers IP as a
> Public IP
Reassure me. What are the first two octets of that public IP address
("a.b" out of "a.b.c.d")?
xxjahasotoxx
Mar 01, 2018Aspirant
- FURRYe38Mar 01, 2018Guru - Experienced User
Glad you got it working.
Enjoy. :smileywink:
xxjahasotoxxwrote:turns out it might have either been a bug with my windows 10 install or even the nvidia software it self I reinstalled windows along with the Nvidia Geforce software and it worked thanks for the help
