keithdpatch
Feb 27, 2023Star
R9000 Problem Streaming Tivo Recordings on Wired LAN
NOTE: #R9000 router with firmware version V1.0.5.42 (latest). I recently replaced my old Tivo Roamio with a Tivo Edge, as I had problems watching shows on the Edge & streaming issues over my Netg...
Feb 27, 2023Guru - Experienced User
So the devices are ethernet connected to the back of the R9000?
What CAT# lan cable are you using? CAT6 is recommended.
Have you tried installing a external Gb LAN switch behind the router then connect these devices to this LAN switch? Something like NGs GS 105/108 or GS-308 would be suggested.
QoS isn't needed for LAN persae rather it's for upstream data flow to the WAN side.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
keithdpatch
Feb 28, 2023Star
Thanks, I'm using CAT5e or CAT6 cables, gigabit switch, etc. And I mentioned "..the Netgear R9000 shows that its Quality of Service (QoS) only works for WAN connections."
I was hoping to hear of a current router brand/model which performs some sort of traffic shaping on LAN connections, as I recall one of my old routers (either Linksys or Netgear) allowing such capability ~8-15 years ago. Looks like I'll continue using my Google machine to try and find a suitable alternative.
